jam 0214 iRA 8105
  • Ronaldo Virgili Floriano
    • Feb 2023
    • 17
    jam 0214 iRA 8105
    I have an iRADV8105 with jam0214, in the 11x17 it only does the front when turning to the back to and gives the jam.em letter ok
  • GIUBOSS
    • 1437
    Re: jam 0214 iRA 8105
    Check flag sensor and spring there, clean rubber rollers. Are the fusers ok?
      • Feb 2023
      • 17
      Yes the fuser is ok
      flag and spring, ok
      clean rollers, ok
      the sheet goes down and stops only at 11x17
      • GIUBOSS
        • 1437
        Does it work with A4? Possible format setting if I understand correctly
          • Feb 2023
          • 17
          yes, on the A4 it works normally, I even executed a CLEAR MN-com, without success.
          • Canuck
            Tech Specialist
            • 1713
            Make sure the Oilite bushings on the delivery assembly have been upgraded to bearings. Also clean the oneway clutch inside the white delivery gear and put a drop of oil inside. How many copies on machine? Back up Dcon, clear it, put in door specs and see if it has any affect. Does it from all cassettes(bypass too)?
