canon IR Adv C5235 black image is spread
  • Afivmd78
    • Feb 2021
    • 11
    [Misc] canon IR Adv C5235 black image is spread
    canon IR Adv C5235 black image is spread while the color print is ok changed drum unit and checked itpb and fuser it all looked fine.20230801101027.pdf20230801101124.pdf
  • GIUBOSS
    • 1436
    Re: canon IR Adv C5235 black image is spread
    You checked the black development unit
    • Buenor
      • Dec 2021
      • 21
      yeah, it coult be dev, but looks very strange...
      clean laser windows at first. Do some color calibrations.
      Maybe stiring a dev in a service menu will help, but if you don't know how - better for you not to use a service menu.
      You can make a print-stop test to check how the image is forming on the belt.
      • Afivmd78
        • Feb 2021
        • 11
        No i have to check dev unit now, very strange issue. Ler me initialise the dev and check
        • wcanonw
          • Aug 2014
          • 404
          Hi, should you be more specific and send more photo evidence of the black drum unit? Is the drum unit you installed new or from another machine?
          • wcanonw
            • Aug 2014
            • 404
            if the drum is new, in the place where the printer is located it is hot climate or very cold climate. if the weather is cold activate the button (Environment Heater Switch) check the service manual to see that button
            • Afivmd78
              • Feb 2021
              • 11
              when we saw issue ,black drum unit is rebuilded ( OPC drum, cleaning blade , PCR , and cleaning Roller changed ) and also showing the same problem ,so we swapped cyan drum unit from the same machine installed it to black. still problem in black .while the black unit which swapped to the cyan is working properly.
              • Buenor
                • Dec 2021
                • 21
                You wrote ITB looks fine, but did you swap with the other known-good one?
                Today I solved a little similar issue by swapping a ITB.
