I have a 3300 that leaves a wavy curl on the trailing edge of 11*17 paper only. Machine has 80k on it. All other paper sizes are fine. Any ideas would be appreciated.Thanks
IR 3300
This was extremely common on the iR330/400 series machines which preceeded the iR3300. The exit roller is the most likely candidate. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
