Canon Ir adv 4535i checking data
  • sly
    • Feb 2016
    • 37
    Hi all, any help or thoughts welcome. Ir adv 4535i will not boot up , screen stuck on checking data.
    I have reloaded latest firmware. Still not booting up, checking data , *2 and 4 on start up all shows good.
    Can not gain access to service mode is this possible without machine booting up, thinking maybe clearing Dc con clear might do the trick? Any body had this issue.
  • ADV COPIER
    Pemain
    • Nov 2022
    • 250
    Re: Canon Ir adv 4535i checking data
    reload system software
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • sly
      • Feb 2016
      • 37
      Hi, thanks for reply.Already done as mentioned in original thread.
      Updated latest firmware/software.
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Did you resolve this?
        Try unplugged the hard drive to see if you can get it to a E602 code...
        Maybe the drive is messed up.
        • sly
          • Feb 2016
          • 37
          Have removed hard drive and reseated. No E602 errors. Hard drive check on *24* is Ok. Still un resolved. Any further ideas would be appreciated.
          • ADV COPIER
            Pemain
            • Nov 2022
            • 250
            change your hdd
              • 8132
              Unplug the HDD then power on with the HDD disconnected if you get an E602 error replace the HDD then reload the system software.
              If you don't have a new HDD format the HDD using the SST then re-load the system software.
              • giogi
                Engineer senior
                • Jan 2016
                • 182
                on the service manuale there is a 6 chapter "Startup System Failure Diagnosis" specific for your problem.
                "Knowledge is a source, but unfortunately ignorance is a sea."
