4545 scan orientation
  • copicatt
    • Nov 2008
    • 366
    I tried to look it up in the forum but I hadnt to come to a conclusion. When you scan letter direction in the feeder, the PDF document shows up correctly on the computer screen. When you scan in the letter-r direction, the scan shows up sideways on the screen. Is there a way to have a letter are to show in the correct direction just as letter. Customer scans, mixed originals with legal and letter, and they are coming out sideways on the screen. Auto orientation for copying is on.
  • bobburnsreb
    • Mar 2015
    • 233
    Re: 4545 scan orientation
    Try selecting scan and send and look under options. Check original content orientation.
    • copicatt
      • Nov 2008
      • 366
      It is set to Top Left, Although I don't ever remember using that setting, and haven't noticed this issue. I feel like there's another setting, but not sure..
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        try
        Settings/Recording : Function Settings : Common Settings > OCR (Text Searchable) Settings > >
        Turn off automatic recognition
        "Knowledge is a source, but unfortunately ignorance is a sea."
