hellp
  • jack8125
    • Oct 2023
    • 7
    hellp
    Canon imagePRESS C700 error code E061-0004
  • ADV COPIER
    Pemain
    • Nov 2022
    • 257
    Re: hellp
    try cleaning laser unit
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • jack8125
      • Oct 2023
      • 7
      Re: hellp
      i clean laser is the firs ting i did
      • wcanonw
        • Aug 2014
        • 404
        Re: hellp
        Hello, why do you clean the laser?
        The service manual indicates the procedure to be carried out to repair the problem.
        change laser black, connectors, cables, pcbs.....
        • bobburnsreb
          • Mar 2015
          • 233
          Re: hellp
          Title : E061-0004 Error Code after replacing the black drum unit
          Adjust the spring tabs inside the drum, pushed toward the drum shaft, to resolve the error code. The tabs inside the drum are located toward the rear of the black drum unit.
          Worth a try, Good Luck!
          • wcanonw
            • Aug 2014
            • 404
            Re: hellp
            That is part of the drum heater system, the prints would come out blurry in black.
            • jack8125
              • Oct 2023
              • 7
              Re: hellp
              thanks i wuill
              • jack8125
                • Oct 2023
                • 7
                Re: hellp
                thas i will
                • jack8125
                  • Oct 2023
                  • 7
                  Re: hellp
                  i replece i put new one still have tha error
                  • wcanonw
                    • Aug 2014
                    • 404
                    Re: hellp
                    Hello, have you already done what the service manual indicates?
