Canon iradv c7065 e733, e753
  • wcanonw
    • Aug 2014
    • 404
    Hello, canon advance c7065, error E733-000, E733-0001.
    changed, main controller 1, main controller 2, dc controller, power supply, hdd. problem persists...
    I would need to install the firmware, I can't get the firmware
  • ADV COPIER
    Pemain
    • Nov 2022
    • 263
    Re: Canon iradv c7065 e733, e753
    try reinstall system software
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • wcanonw
      • Aug 2014
      • 404
      Place another hard drive and it showed error E602-4000, E602-4001, return your original hard drive to the printer, it was formatted with the option that comes in the firmware via USB.
      When installing the firmware, it remains in the dcon option and error E753-0001 appears. Checking the computer with the sst program, the firmware has dcon version 7002. Does the printer ask me for dcon prior to or greater than dcon7002?
      • wcanonw
        • Aug 2014
        • 404
        Hello, yes I have the firmware, possibly the firmware is already discontinued, as I tell you, the dcon is version 7002 when I check the firmware using the service support tools (sst) program.
        • wcanonw
          • Aug 2014
          • 404
          What firmware version is the most up-to-date for the Canon C7065, I don't have the most current firmware
          • ADV COPIER
            Pemain
            • Nov 2022
            • 263
            your file is not corrupted ?
            • wcanonw
              • Aug 2014
              • 404
              Possibly it is damaged or perhaps the firmware is already old, I cannot rule out if the firmware is damaged
              • wcanonw
                • Aug 2014
                • 404
                Any friend from technical support can send the firmware for the canon c7065...
                • ADV COPIER
                  Pemain
                  • Nov 2022
                  • 263
                  check PM
