E060-0070 on CLC 1150
  • meris
    • Sep 2008
    • 10
    Hi
    I have problem with my CLC 1150:
    When I turn on the copier it shows E060-0070 error.
    Manual said:
    Timing of detection: The grid bias output value is 900 V or more.
    Cause: The grid bias is at the upper control limit.
    That doesn't tell mu much. After few turn on - turn off, the error goes away. Then I can make 10 - 20 copies and the error show's up again. Then turn on - turn off several time, then I can make another 10 - 20 copies.
    Any clue on that? How to fix it?
    Meris
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    yes its easy three things you can do
    1 :- Rewire the corona unit including the grid (sometimes works)
    2 :- Clean the corona unit fully side shields and frame to remove all ozone deposits (sometimes works)
    3 :- The best option fit a new corona unit (always works)
    depends how many copies the machine done age of unit etc etc if you go into service mode * 2,8* then copier then counters look under misc durable1,durable 2 you will see the count of the corona unit to see what percentage its at ie 150% and make a judgement call from there
    cheers
    • meris
      • Sep 2008
      • 10
      Thanks a lot
      I'll try that!
