Canon IR c3800 series - How to i do sensor tests in Service Mode ?
  • Jedi Ben
    Senior Engineer
    • 79
    Hi fellow Engineers!
    wondering if any Canon techies can help me out?
    on older models the sensor test always seemed to of been in SITUATION TAB / then TROUBLESHOOTING TAB sensor test. But on the these 3800s its not there. We have become a Canon dealer on top of 6 other manufactures
    I have looked in the service manual that also states it is in Situation tab but it is not?
    last time i worked on Canons was the GP range i remember you could find sensor tests elsewhere in service mode but its lost me
    any help would be very much appreciated as Canons seem to be flying out the door to customers and will soon come in with the faults. not figured out motor tests yet
    thanks
    Ben
  • Larhal
    • 583
    Re: Canon IR c3800 series - How to i do sensor tests in Service Mode ?
    thanks
    Ben
    In service mode go to Function, Parts-Chk.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • Jedi Ben
      Senior Engineer
      • 79
      Thanks Larhal,
      looked in there today. i can find motor check and motor on. also solenoid tests but not sensors.
      Noticed a lot listed is abbreviations. Presume sensor should be something like SNR ?
      • Radiscar
        • Jun 2019
        • 74
        you can in theory check the sensors in the I/0 in service mode but Canon has mentioned to not rely on it anymore.
        There should indeed be a sensor check in situation mode - it might be a bit hidden? it should be on the second page on it's own as sensor check
        I find if there are any jams the jam codes will have the sensors in the info along with a diagram where the sensor is. (service mode>copier>Display>jam) highlight the jam and click the i info button at the bottom of the screen.
        error codes are similar; it will mention what's what in that info button so you don't have to look it up unless its non typical, multiple error codes, or a weird issue due to the customer...
        • Jedi Ben
          Senior Engineer
          • 79
          Thank you for your time to type and let me know. i appreciate it.
          I have Done years of Ricoh / Xerox/ HP/ konica/ Lexmark but the Canon service mode totally swings me. Im sure once i get passed call out 50 on them i will be up to scratch lol
          cheers
          ben
          • Larhal
            • 583
            Hi Ben,
            When you open a window in the service mode and you don't know what the items mean you can touch the green ball, at the bottom of that screen, with the I in it for information. it will open up an explanation next to the item.
            Larhal
            • Jedi Ben
              Senior Engineer
              • 79
              Hi Ben,
              thank you Larhal,
              ive just tried that its very useful. i have also found the sensor check and motor check. it is on SITUATION mode but i didnt see the arrow to the right at the bottom which its then there lol. so im all good
              thanks Guys great help
