E0263-1630 C7565 v2
  • RicheyRich80
    • Oct 2023
    • 8
    E0263-1630 C7565 v2
    Have replaced the fixing feeder driver PCB. Still getting E0263-1630. Anyone see this problem before?
  • bobburnsreb
    • Mar 2015
    • 230
    Re: E0263-1630 C7565 v2
    263-1630-05 Power supply error
    Detection Description The 6 V supply to the Fixing Feed Driver PCB was not detected.
    Remedy [Related parts] R1.00
    - Harnesses connecting the DC Controller PCB (UN2/J1222), the Drawer Unit (J8023) and the
    Fixing Feed Driver PCB (UN5/J1510)
    - DC Controller PCB (UN2)
    - Fixing Feed Driver PCB (UN5)
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2
    min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
