Canon iR Advance 4045 error code code:E110-0002
  • sagabra
    • Mar 2023
    • 3
    [Error Code] Canon iR Advance 4045 error code code:E110-0002
  • ADV COPIER
    Pemain
    • Nov 2022
    • 246
    Re: Canon iR Advance 4045 error code code:E110-0002
    check laser unit
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • sagabra
      • Mar 2023
      • 3
      • ADV COPIER
        Pemain
        • Nov 2022
        • 246
        DC board ?
        • Brian8506
          • 1664
          If you highlight the error code in service mode it will tell you what to check. Probably needs a laser
            • 8125
            Originally posted by sagabra
            Canon iR Advance 4045 error code code:E110-0002. What’s the code about? What’s should i do.
            • Code: E110-0002
            • Description:Failure of the Polygon Motor (M11)
              The speed lock signal indicates a deviation 10 times in sequence at intervals of 100 msec after the signal has indicated a locked state. * The same condition is detected after the error retry is performed.
            • Remedy:1. Update the system software 2. Check connection of the Connector (J1/J7/J10/J21/J208/ J8142/J8143). 3. Replace the Laser Scanner Unit. 4. Replace the DC Controller PCB (UN2).
