Canon IR adv C5535i E302-0003
  • Elmo
    • Feb 2010
    • 541
    Hi All
    on a batch of ex lease machines i have 1 with a fault it is low mileage sub 50K
    when copying via the document feeder i get e302-0003 code
    i have tested a different feeder and updated firmware but still i get the same code
    machine works fine when copying from the glass
    any advice
    I Used To Live To Fix Things Now i Fix Things To Live
  • copier tech
    • 8221
    Re: Canon IR adv C5535i E302-0003
    Originally posted by Elmo
    Hi All
    any advice
    Are you sure this is the correct error code, Can't see E302-0003 listed ?
    However I would start by updating the system software,
    • Elmo
      • Feb 2010
      • 541
      E302-0003-04 Error in paper front white shading
      Detection Description The paper front white shading value gradually became out of the specified range.
      Remedy [Related parts]
      - Harness between the Reader Scanner Unit (J101) and the Reader Controller PCB (J105)
      - Reader Scanner Unit
      - Reader Controller PCB
      [Remedy]
      1. Clean the LED, mirror, and Stream Reading Glass of Scanner Unit.
      2. Check/replace the related harness/cable, connector and parts.
      [Reference] Before replacing the Reader Controller PCB, back up the service mode data (approx.
      2 min) and restore the backup data after the replacement so the data may be able to be protected.
      - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> RSRAMBUP
      - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> RSRAMRES
      Found this will check it out in the morning
      • Elmo
        • Feb 2010
        • 541
        was an odd fault
        when copying colour or b/w on the glass worked fine
        when copying b/w thru adf worked fine
        Error only occurred when copying colour thru the adf
        Turned out to be a staple on the Reader Controller PCB
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Very common to see this. Clean the optics, mirrors, scratch the glue off the bottom mirror to slide out for cleaning. Then do white level calibration x4
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Elmo
            • Feb 2010
            • 541
            Thanks Venom
            Your advise helped turned out to be the optics unit faulty
            possibly caused by the staple on the controller pba
            stripped and cleaned optics and adjusted still same
            replaced the optics did adjustment and now working fine
            • RicheyRich80
              • Oct 2023
              • 8
              If it works fine off the glass but only does it when scanning from the ADF then most likely its the scan flat harness. FM1-T689-000.
              • Radiscar
                • Jun 2019
                • 74
                I think it is a minor miracle sometimes how a staples, etc can get into the machine; I once had one of those huge paper clips on a pcb in the adf. No clue how it made it's way there.
