IR400 DADF-A1
  • resi
    • 14
    IR400 DADF-A1
    Hi Techs,
    I am havin big headache with this dadf; jams at all areas of this unit, even after thoroughly cleaning all the rollers. It would work for a few documents and start jamin again. Pse help. I have done the adjustments, like it says in manual, to no avail.
  • Brian8506
    • 1666
    You sure it's not the C-1. I don't see the A-1 listed in the parts catalog. If it's the C-1 with all the individual belts and rollers, you should replace them. If it's the feeder with the big feed roller and sep pad, the pad can cause problems.
    • kwazimoto
      • Jan 2007
      • 199
      df
      it could be a dadf-b1 it stands for bad ...lol try a new sep pad.. and clean rollers
      • resi
        • 14
        IR400 DADF-A1
        Brian, its definitelly the A1, with the 3 adustable screws, post-feed.
          • 23010
          The biggest problem that I had with these feeders is the inside of the separation and feed belts getting dirty. Clean he outside all you want, but if the inside is still slipping, your screwed.
          I usually disassemble the entire belt assembly and in a sink of sudzy water scrub up all the belt and pulley surfaces with a toothbrush. If it's got over 150K on the feeder replace all the tires, belts, etc. Those tires don't get any better with age.
          By the way it is a DADF-A1. =^..^=
          • resi
            • 14
            IR400 DADF-A1
            Thanks man, Blackcat,
            I did soak the belts in soapy water and cleaned the inside......Thumbs up, buddy.
