IR 5030i and scan to email - TLS
  • Mr.Prebus
    • Dec 2023
    • 10
    Hello.
    I am new to this forum, and have searched a lot for this problem. I can`t find a solution who works for me and then i try this excellent forum.
    Is there a way to come around the problem with TLS and certificate on IR 5030i? is there any firmware update who opens the possibility for TLS?
    Regards
    Prebus
  • bobburnsreb
    • Mar 2015
    • 233
    Re: IR 5030i and scan to email - TLS
    Check your PM
    • Robin Lord
      • Dec 2023
      • 2
      assuming you are talking about Canon IR ADV C5030 then yes, update your machine to the lastest version and it will support TLS V1.2. Side note, smtp comunication port can only be changed in service mode for this model
      • Mr.Prebus
        • Dec 2023
        • 10
        QUOTE=Robin Lord;2560746]assuming you are talking about Canon IR ADV C5030 then yes, [/QUOTE]
        Yes. That's correct, it is adv. Then it is just to find the correct firmware.
        Thanks for information.
        • Mr.Prebus
          • Dec 2023
          • 10
          Hello.
          I am still searching for the latest European firmware to this unit. If anyone have it, i would be happy for a PM.
          Regards
          • ADV COPIER
            Pemain
            • Nov 2022
            • 256
            Originally posted by Mr.Prebus
            Hello.
            Regards
            v87 ?
            Let's Drink our Coffee
            WhatsApp +62895325228383
            • Mr.Prebus
              • Dec 2023
              • 10
              yes, or somthing over 85.02
              • ADV COPIER
                Pemain
                • Nov 2022
                • 256
                I have v87 only
                • Saturn
                  • Nov 2023
                  • 171
                  Hello.
                  Regards
                  You can update the firmware via service mode.
                  I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
                  • Mr.Prebus
                    • Dec 2023
                    • 10
                    Hello.
                    No, it will not communicate with server. I read somewhere that it not works any more. my be i have wrong address or something.
                    • Robin Lord
                      • Dec 2023
                      • 2
                      Hello.
                      it still work, if you have v87 (tls 1.2 suported) and both updater and smtp dont work i would bet you have bad dns or gateway setup (check carefully your network set up) or there is restricions on the trafic in your network. smtp comunication port must be set in service mode
                      • Radiscar
                        • Jun 2019
                        • 74
                        Hmmm...i think there was an address that was updated at some point; but only for ERDS/Com-test stuff?
                        service mode > copier > function > install > RGW Address > http://b01.ugwdevice.net/ugw/agentif010
                        I would check Gateway, DNS, and time​ first though.
                        • Mr.Prebus
                          • Dec 2023
                          • 10
                          Hello.
                          With Gmail it works now. The problem was that pop RX must be activated to get some kind of verification.
                          Thanks for excellent help from this forum.
                          • ninhhung
                            • Apr 2023
                            • 4
                            Hello.
                            You can update FW via Updater in service mode if you have connect internet
                            • ntheodor
                              • Jan 2024
                              • 1
                              Dear all i have a c5030 with firmware installed iAC5051_V2v551001us could you please help me with a new firmware so i can use smtp with gmail provider
