IPF8300 error E161-403F
  • makadam
    • Aug 2016
    • 12
    I have a problem with Ipf 8300 with error E161-403F. I replaced Left printhead plotter worked with 2 small prints and now I have the same error. I already checked 8300 service manual but this error does not exist only E161-403E. In Ipf9000 service manual when this error appear manual point to check main unit electrical equipment: 1. Flexible cable, 2. Main controller, 3.Head relay PCB and 4. Carriage PCB. I noticed on internet that a lot of IPF plotters have this problem and maybe someone will share information how to repair PCB without change them.
  • williemarquardt
    • Feb 2024
    • 2
    Re: IPF8300 error E161-403F
    I also get the same error. Did you find the solution?
    • williemarquardt
      • Feb 2024
      • 2
      I have a problem with Ipf 8300 with error E161-403F. I replaced Left printhead plotter worked with 2 small prints and now I have the same error. I already checked 8300 service manual but this error does not exist only E161-403E. In Ipf9000 service manual when this error appear manual point to check main unit electrical equipment: 1. Flexible cable, 2. Main controller, 3.Head relay PCB and 4. Carriage PCB. I noticed on internet that a lot of IPF plotters have this problem and maybe someone will share information how to repair PCB without change them. uno online
      Update: I found the solution. My problem is solved.
        • 23007
        I suspect that you changed the printhead. Is that correct?
        That's the usual culprit. =^..^=
        • makadam
          • Aug 2016
          • 12
          I change left printhead but situation was the same. After installing new flat cable no more error messages.
