iradvc5235 - E075-002
  • MunsterTech
    • Sep 2014
    • 381
    [Error Code] iradvc5235 - E075-002
    Hi,
    Was passed this by another tech. Initially it was magenta marks on copies, he replaced the mag drum,
    but the machine went into E075-002. He checked the ITB and thought it was OK, he replaced the whole ITB assy from another device
    but same error. The machine was brought back to our warehouse, I checked all the wiring and connectors, no bent pins etc, I replaced the DC controller as per manual, but still error exists, itb motor doesn't turn at all. Any ideas?
    Machine is about 7 yrs old, approx 450k on it, roughly 50% colour vs mono. Firmware upto date.
  • copier tech
    • 8142
    Re: iradvc5235 - E075-002
    Originally posted by MunsterTech
    Hi,
    • Code: E075-0002
    • Description:Timeout error in searching ITB steering HP
      Unable to detect change (Low -> High or High -> Low) of ITB Steering Sensor Signal although 10 sec has passed.
    • Remedy:1. Check if the ITB Connector is physically removed. 2. Check if the cable of the ITB Unit is open circuit (including the inside of the ITB Unit). 3. Replace the ITB Displacement Control Motor (M14) and its Drive Assembly (the gear, Drive Shaft, Mounting Plate, etc.). 4. Replace the DC Controller PCB (UN1).
    • MunsterTech
      • Sep 2014
      • 381
      Hi
      The itb assy has been replaced with another and also the DC controller has been replaced, still has the error E075-002.
      • copier tech
        • 8142
        Hi
        Did you run ITB-POS in service mode ?
        • MunsterTech
          • Sep 2014
          • 381
          No, it goes straight into error state, the itb motor doesn't turn at all. Replaced the whole itb assy
          and same issue, dc controller replaced, still same issue.
          • copier tech
            • 8142
            Double check the wiring loom
            • Radiscar
              • Jun 2019
              • 74
              ...just to make sure -after doing all this work and making sure the belt is centered; did you ERR-CLR and reboot the copier?
              The copier should need a error clear as it doesn't want to move the belt and potentially damage it.
              • MunsterTech
                • Sep 2014
                • 381
                Yes, the error is cleared, the machine on reboot tries to go in rotation, cassette lifters start to lift, then goes into error.
                the ITB motor doesn't turn, a different ITB assy does the same.
                • Radiscar
                  • Jun 2019
                  • 74
                  This is quite the head scratcher honestly but
                  it should not be anything to do with the ITB assy despite the error since it was swapped out
                  it could be the wiring, something in the back of the copier -etc...or...
                  the issue occurred right after replacing the magenta drum so that could be the cause somehow?
                  its a bit of a reach but should be easy to check.
                  • copier tech
                    • 8142
                    Well, as the error only happened after replacing the magenta developer unit, try fitting the old one back.
                    • MunsterTech
                      • Sep 2014
                      • 381
                      Sorry, don't have the original drum, this was passed over to me from another tech. I'll have another look soon. Tks for the help
