E747-ff00 with imagepress c1 plus
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 172
    Dears all:
    As in title thread that we face this error with sub-code which is not mentioned in service manual
    The action was taken as:
    1-updated the firmware for last version
    2-main control pcb had replaced
    3-Dc control pcb had replaced
    No result error still as it
    Can anyone tell what the sub-code is exactly related to.
    Thanks in advance
    Sent from my CPH2239 using Tapatalk
  • ADV COPIER
    Pemain
    • Nov 2022
    • 263
    Re: E747-ff00 with imagepress c1 plus
    SDRAM has poor contact
    Let's Drink our Coffee
    WhatsApp +62895325228383
      • Mar 2012
      • 172
      Many thanks for your interest but we also replaced SDRAM without result
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        DDR-SDRAM 1 or 2 on main cont.
        Bypass PCB
        HDD
          • Mar 2012
          • 172
          Bypass PCB
          HDD
          Do you mean bypass pcb by this that driver side board (fm2-7731)
          • zoraldinho
            • Mar 2008
            • 5018
            My mistake. C1 has only one main controller and no bypass pcb.
            The C800 series has a bypass pcb on controller 2 which is often the reason for the E747-ff00.
            Try to clean contacts on ddr rams.
            • wcanonw
              • Aug 2014
              • 404
              clean the contacts of the sub cards, ram memory and sd ram, bootrom with eraser or lint-free paper
              • wcanonw
                • Aug 2014
                • 404
                The other thing that could be is a failure of ram memory or some sub card.
                Once I had a similar error but with a different subcode that was not in the service manual.
                They had changed the entire main drawer, but they forgot to put the other ram memory, there are c1 printers that work with one ram memory and others that work with two memories, the error appeared when they sent prints with large files, the solution was to add the another ram memory that was missing
