Canon iR ADV C5255
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR ADV C5255
    Hello:
    Could anyone please help me with this problem?..
    The machine is a Canon iR ADV C5255. I had changed the Magenta Drum unit, clean all conectors and sensors but the did not solve the problem.
    Thanks..
  • copier tech
    • 8221
    Re: Canon iR ADV C5255
    Originally posted by luis1984bol
    Hello:
    [ATTACH=CONFIG]61769[/ATTACH][ATTACH=CONFIG]61770[/ATTACH]
    Thanks..
    Check the magenta dev unit, the drive gear can break. Also check the mag dev drive coupling in the back on the machine, these can also break.
    • doktor
      • 215
      Laser hatch ?
      • techandtrader
        • Jun 2016
        • 335
        All of the developers in the c5200 series have the updated gear unless someone put in a C5000 dev unit. Like Copier Tech said, the coupler should be checked but thats a long shot that the main drive or that is broken. Other than that looks like a failed laser unit. Broken hatch as mentioned. I had a c5000 do this many years ago with yellow. I think the firmware was upgraded in c5200 to code and shut down the printer for this. e100
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
