Impossible to get smtp to work [Canon C351]
  • carlsson
    • Apr 2021
    • 35
    [Misc] Impossible to get smtp to work [Canon C351]
    My brother in law got hold of a used C351, and I have helped him to install it.
    However, it's effing impossible to get the machine to send emails with the scan to mail function! It tries for a bit, and then ends with an error (#933 if I recall correctly, which means nothing the list I looked at).
    I have a C5235 myself, and that works just as it should. I set up the C351 exactly the same, to no avail. Seriously, this should not be that hard.
    So, some questions:
    1. Since this is a used machine there may be some settings that I have overlooked. Is there a way to factory reset the machine without destroying anything important (like calibration etc) ?
    2. It's extremely tiresome to try a setting, restarting and wait for the result. Why in heavens name did Canon not just create a "Test SMTP settings" functions? Or is there?
    3. Any ideas on where to look without a reset?
    4. I have looked for a newer firmware, but the Canon site says that "I have the newest version". How does it know that, I have not given any info about the machine...? Where can I find the newest firmware?
    Device Basic Information
    Manufacturer : CANON INC
    Device Name : iR-ADV C351P
    Product Name : iR-ADV C351
    Serial Number : QNV05xxx
    Version Information
    Main Board Version : 9
    Controller Version : 4101.0.2101
    Any help would be highly appreciated, I'm quite stuck.
  • techandtrader
    • Jun 2016
    • 335
    Re: Impossible to get smtp to work [Canon C351]
    I would run the Init all data so the interface is all set back to default. Always a good idea on a newly acquired box.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • Saturn
      • Nov 2023
      • 171
      The latest Firmware is v41.02.03, Date 2023.03.07. You can find the firmware in the Canon SIMS portal. However, only registered Canon technicians have access to that.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • alex@wocltd.com
        • 430
        firmware wont make any difference - if you 5 series is working fine do an export via rui after doing an init data - alternatively set up scan to folder?
        • Hart
          • Feb 2024
          • 415
          I don't know Canon but maybe the model is too old and can't use TLS 1.2 (or whatever version your SMTP is using) ?
          • Radiscar
            • Jun 2019
            • 74
            sometimes one of the encryptions is left unchecked on the older models but is needed for the certain scan to email/network.
            settings/registration, preferences, network, TLS.
            Check the encryptions and the allowable tls versions.
            I'm assuming the port is okay.
            Print out the settings/registration, preferences, output report and just check everything.
            • copier tech
              • 8169
              So, some questions:
              Version Information
              You've not said how far you have got troubleshooting, I trust you have confirmed the basic connections are correct, gateway & DNS etc? I usually turn on DHCP to allow the device to pull all the network settings.
              Do you know how to check / change the SMTP port number on this device? (in service mode)
              We can supply the latest firmware, if you've tried the above.
              • carlsson
                • Apr 2021
                • 35
                Thanks for the input! 🙏👍
                Initialize all data seems like a good start. Do I follow these steps? Initializing All Data/Settings
                • Hart
                  • Feb 2024
                  • 415
                  Sometimes you need to use the port 465 (SMTP SSL/TLS) instead of 587 (SMTP STARTTLS)
                  • carlsson
                    • Apr 2021
                    • 35
                    This is embarrassing, but I have to follow up if someone else have the same problem.
                    It turns out that when you turn off DHCP on the printer (because I generally want printers on fixed IP's), it also zeroes out the DNS records. I didn't notice, and the printer can't of course find any mail servers without DNS's...
                    I don't know if it's because generally DNS records stay put when you turn off DHCP, or the clunky GUI of the Canon, or that I'm just that stupid!? Probably a combination. Sorry to have wasted your time! 🤦*♂️
                    • ADV COPIER
                      Pemain
                      • Nov 2022
                      • 256
                      So, some questions:
                      Version Information
                      make sure the port
                      pop3 995
                      imap 993
                      smtp 587 (gmail/yahoo) 465 (hosting)
                      If you want to factory reset there are 2 ways:
                      - clear all ram
                      - reinstall firmware --> Format --> update (Auto)
                      Let's Drink our Coffee
                      WhatsApp +62895325228383
                      • LeYou
                        • Jan 2025
                        • 1
                        Hi, i have the same issue with my canon c3226i. The SMTP check only works when I use port 25, but mails are not sent. It worked fine until yesterday. Now i can't scan and send in emails... It gives me an error 801. Can someone help me? It's the main copier we use at work.
                        • techandtrader
                          • Jun 2016
                          • 335
                          If you create a SMTP and use the IP address then DNS becomes meaningless. Using an actual IP address is what you do when it doesnt work with all correct settings.
