[Canon 5550i] images problem
  • tjrtkdqja123
    Banned User
    • Feb 2022
    • 21
    [CQ] [Canon 5550i] images problem
    The left side is a normal machine, and the right side is a problem machine.
    This is chart number 10 on the test page, and it appears as if there is fog.
    It's an automatic color correction pattern, but it seems like the 4 colors of black appear as blue.
    Things I've tried
    4-color drum replacement,
    Patch sensor inspection
    Developer BK, C replacement
    Toner is not provided and the same toner is used as the left pattern machine.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: [Canon 5550i] images problem
    Can you post a pic of PG-10 from service mode please.
    • tjrtkdqja123
      Banned User
      • Feb 2022
      • 21
      Thank you for your answer
      This is test page 10.
      The middle is the original,
      adjust - hv-tr 2tr off
      Left is -100
      If the right side is + 100.
      • zoraldinho
        • Mar 2008
        • 5009
        Is the image on ITB ok?
        the sec.transfer roller could be causing problems.
        If it's not ok:
        Try replacing the dc from another device.
        • tjrtkdqja123
          Banned User
          • Feb 2022
          • 21
          thank you for the answer.
          I tried replacing the belt Assy, but the symptom is the same, so I will check DC.
          • zoraldinho
            • Mar 2008
            • 5009
            I didn't tell you to change the transfer belt. Check the image quality on itb! If it is ok, replace the sec transfer roller.
