IRA400 Scan
  • Brian8506
    • 1667
    IRA400 Scan
    I found the solution to this a while back and can't remember it. When I put an original on the glass and hit start, it scans it and then gives me the option to scan more, cancel or start copying. I just want the machine to make the copy when I hit start. I know it can because the customer has a second 400 that just goes right into copy mode. Compared the settings with no luck. Any help would be appreciated.
  • Saturn
    • Nov 2023
    • 172
    Re: IRA400 Scan
    If the "Collate" function is set as default, the machine will do exactly what you have described. If you turn off the collate function, it will start immediately.
    I've checked it with an iR ADV C5550i. The iR ADV 400 should do the same.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • Brian8506
      • 1667
      Re: IRA400 Scan
      Originally posted by Saturn
      I know this from Ricoh machines. If the "Sort" function is set as the default, the machine will do exactly what you have described. If you turn off the sort function, it will start immediately.
      • Saturn
        • Nov 2023
        • 172
        Re: IRA400 Scan
        Don't worry, I notice that all the time too, I'm over 50
