Canon iRA C5540 no display
  • aAandy
    • Apr 2012
    • 370
    [Dead] Canon iRA C5540 no display
    hello everywon
    when this machine is turned on, the engine runs up normally, scanner and ADF initialise normally, fans operate, main power and power save are lit but no display
    checked 5v 12v and 24v all good - main controller PCB has no LEDs lit and the ethernet connector has no lights flashing when plugged into network - riser PCB has one LED lit
    i suspect main controller PCB! anyone seen this before to confirm?
    thanks in advance
  • ADV COPIER
    Pemain
    • Nov 2022
    • 264
    Re: Canon iRA C5540 no display
    try replace main controller
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • Saturn
      • Nov 2023
      • 172
      Confirm, in over 90% of cases the reason is the main controller.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • aAandy
        • Apr 2012
        • 370
        thanks gentlemen,, suspicion confirmed,, main controller it is
        • MOLICN
          • Mar 2024
          • 26
          Your fault is due to protection caused by incorrect motherboard data.
          The solution is as follows:
          Short circuit the JP1 and JP2 pins on the motherboard with tweezers to attempt data recovery.
          Method 1: Short circuit JP1: The host will automatically power off. Note that the red LED on the motherboard will flash for 2 seconds before switching to the green light. Remove the tweezers, shut down the machine normally, and restart to see if it can recover normally.
          Method 2: Short circuit the JP2 host and restart it. Pay attention to the LED display of the machine. When the LED shows a green light, shut down and wait for 1 minute before turning on the machine to see if it can be restored.
          • aAandy
            • Apr 2012
            • 370
            thanks for the post Molicn, but seeing there are no LEDs lit on the main controller, it is DEAD
            • aAandy
              • Apr 2012
              • 370
              so i replaced the main controller with a used one, machine ran up fine but called error E197-2003 (communication error between Main Controller and DC Controller) swapped out Riser PCB and DC Controller, but the error remains - perhaps the replacement Main Controller is faulty?
              i'm going to try a firmware update first and see if that does anything - any further assistance/suggestions/tips/tricks/tweaks would be very much appreciated
              thanks!
              • ADV COPIER
                Pemain
                • Nov 2022
                • 264
                If you replace the PCB, try updating the firmware
