Martin
Oce Plotwave 350
Look like the post have been deleted, for some reason.
The issue with the machine were that unless using a A0 role the paper would get stuck/jamming, when it start role from the loading bay.
It did not matter if you swap from bay 1 to 2, ore you tried with a A4, A3, A2 ore A1 role. Unless it were an A0, the paper would jam and you had to open op the loading bay and use the cut button to get it free.
I never figure out the issue.Comment
so this is weird situation…;( if nothing is visible like some obstructirs on paper path and e+ goes smooth than it also could pe programm error.
i had last days pw340 that takes paper until registration and make jam -likes the sensor on registration not working. machine starts working after totally eeprom reset on and finally replace spider core pbaComment
well hard to see what going on, but have not notice anything, that looked wrong. a month before the issue i change a gear that were broken, but everything worked find after that.
the issue first came after i moved it to a new location, because of some office changes. maby a sensor have gotten out of line somehow.
I dont have any technical spreadsheet, to analyses where what is placed, so i could narrow down the sensor controlling it.
Guess a factory reset would not reset the eeprom, just to rule out a hick up in the program/sensor alimentComment
