Ir330 w dadf b1
  • Brian8506
    • 1665
    Ir330 w dadf b1
    Anyone know what else besides the sep pad will make this feeder multi feed originals. TIA
    • 23009
    Lots of things. What jam codes? =^..^=
    • Brian8506
      • 1665
      It's not jamming, it's multi feeding. There wouldn't be any jam codes.
      • Tim C
        • 167
        I have seen tension adjustments work in many cases.. To the left of the belts there is a white center arm with an adjustment screw along with a locking nut. I have moved this tighter and created more tension. and clean the belts and rollers with WD40 on a rag. Followed by some acohol.
        Might help. Jam codes will tell you extactly where the problem is occuring.
        • 11x17
          • Apr 2007
          • 153
          Tim-I think the B1 is the df with a single sep pad and not the one youre describing (A1) I have heard people stretching the spring that exerts sep pressure on the pad but for the most part pad replacement fixes multisheet feeds.
          • Tim C
            • 167
            Ahhh The B1, Yes you are correct. I was not thinking of that feeder.
            • roho
              • Mar 2009
              • 844
              There has been a modification to the spring-it's been released as a bulletin-I don't have access to the publication in question.
              It refers to double feeding and the spring pressure.
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Newer version
                The B1 has always been notorious for multi feeding, as has the K1 on the iRC3200 (just a renamed B1). I have put sep pads in much sooner than the rated life on the part. The K1 pad went thru a slight redesign to improve the friction properties of the pad. You could try one of those...
                FF6-2455-020 The 3 white dots on the black plastic to signify it was the newer version always made feel much more assured of it's improvement
                • roho
                  • Mar 2009
                  • 844
                  The K1 pad assembly won't fit the B1-Best to replace the pads often-try a new spring as well. You may try modifing the pressure of the old spring.Those feeders were often problematic!
                  • Canuck
                    Tech Specialist
                    • 1713
                    Notorious for multi feeding.....yeah...stretch the spring...it helps. What I have done on problem machines is install the friction material from a ir3300 sep pad...you can order just the stick-on "tape" for the sep pad. Cut it and overlap the existing pad. Stupid design....pad too short and wrong angle to separate sheets properly.
