Canon C356ii drum life remaining?
  • thinkink
    • Apr 2016
    • 62
    We are needing to take over service on some Canon IR C356if printers and are not very familiar with them. Is there a way to see the remaining drum life on these printers. The consumable status only shows the toners and no the drums.
  • Saturn
    • Nov 2023
    • 171
    Re: Canon C356ii drum life remaining?
    Enter Service Mode and go to Copier>Counter>LF to see the percentage use and Copier>Counter>DRBL-1 On page 1 (PT-Drm) you will see the counter of the black drum and on page 4 (PT-DR-Y, PT-DR-M and PT-DR-C) you can check the counters of the color drums.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • thinkink
      • Apr 2016
      • 62
      Originally posted by Saturn
      In Service Mode go to Copier>Counter>LF to see the percentage use and >DRBL-1 page 1 (PT-Drm) to see the counter of the Black Drum and page 4 (PT-DR-Y, PT-DR-M and PT-DR-C) to check the counter of the color drums.
      Thank you!
      • Brian8506
        • 1665
        Service mode/counter/LF
        • copier tech
          • 8169
          The LF is just a guide. We don't often see these C-EXV 55 drums go much over 100% without causing a print quality issue. (usually faint prints)
