iRADV8595 firmware can't update
  • Blues Guy
    • Aug 2009
    • 216
    Good day guys,
    We have a unit iRADV 8595 with firmware version 46.36 MN Con and we try to update it to version 74.12 MN Con by using USB
    it's giving a message standard partition error after download firmware completed.
    The machine firmware still showing 46.36 MN Con but for DC con and R con version have updated. I try format the hardisk and
    reload the firmware still the same. Any one of you have come across this problem ? Thank you
  • ADV COPIER
    Pemain
    • Nov 2022
    • 257
    Re: iRADV8595 firmware can't update
    you select menu update or upgrade ?
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • Blues Guy
      • Aug 2009
      • 216
      • ADV COPIER
        Pemain
        • Nov 2022
        • 257
        you read manual?
        • Blues Guy
          • Aug 2009
          • 216
          you read manual?
          I appreciate if you can enlighten me how can I upgrade it. We have previous machine which we upgrade with no issue.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Something did not load correctly with sst. Can you use cds upgrade? (via network)
            • copier tech
              • 8176
              Originally posted by Blues Guy
              Good day guys,
              Are you using the correct system software, is your device the 3rd generation or the previous version ?
