Canon IR Advance 6055 - The Photocopy Result is faded at the bottom of the paper
  • 813200217
    • Oct 2014
    • 53
    [Misc] Canon IR Advance 6055 - The Photocopy Result is faded at the bottom of the paper
    I am an end user
    My hired tehcnician already done a lot of things to solve this problem
    The photocopy result is faded at the bottom of the paper
    perhaps already spent more than 40 hours
    still not solved
    i live in the city where there is just one technician
    he can handle very well my others canon machine
    this one is really stresfull
    please, really need advice to solve this problem?
  • Brian8506
    • 1667
    Re: Canon IR Advance 6055 - The Photocopy Result is faded at the bottom of the paper
    We need to know what he's done so far. There's wires, the developer cylinder, possible bad toner, clean out dv unit and start fresh, transfer belt, dirty optics, etc. Tell him to post.
    • Brian8506
      • 1667
      I just had a similar problem. There may be a broken gear on the back of the developing unit or the stirring rod inside of developing unit might be broken
      • copier tech
        • 8220
        Originally posted by 813200217
        I am an end user
        [ATTACH=CONFIG]62357[/ATTACH]
        still not solved
        Does the technician or yourself have the service manual ? if so there is a troubleshooting section covered in there.
        • 813200217
          • Oct 2014
          • 53
          I have 3 canon ir Advance 6055
          Machine 1 : the faded result
          machine 2 : in good condition
          machine 3 : in good condition
          the things that have been done is:
          1. Changing wires, not solved
          using wires parts from machine 2.. not solved
          2. Developer units.
          Check developer unit.
          using developer unit from machine 2.. not solved
          3. ETB part (1 unit transfer belt)
          using etb part from machine 2.. not solved
          4. Cleaning the laser unit
          not solved
          5. Drum unit
          Move 1 unit drum from machine 2 to machine 1 .. not solved
          6. Change the developer motor unit in the back machine
          i don't know what exactly what is that part called
          he tried all that things in just one hour..
          change the complete part.. still has a faded result
          The technician have never done this before
          change the part in one set from machine 2 to machine 1
          he just focus the troubled machine...
          is that possible because of the gear in the back machine
          by the way, machine no.1 already five years old
          i already have a joke with the technician. maybe i need to change technician
          he fixed my machine for about 12 years.
          • Radiscar
            • Jun 2019
            • 74
            Try swapping the Pre-registration Assembly and PCB that's under it. I've had white "snowflakes" or speckles on images when that PCB failed.
            Also check the connection on the etb cleaning assembly/swap it, I once forgot to plug it back in once and my weird jam went away (paper just flipped over before reaching the fuser)...but the image became faded.
            • mramlawi
              • Jul 2011
              • 838
              Did he clean the laser filter ?
              did u made clear Dc for the machine
              it looks its toner cylander problem broken gear or the stiring roller is broken
              is it from first copy made this , are you making a copy or Print ?
              Distinguished road makes you jewel in rough
              • 813200217
                • Oct 2014
                • 53
                Both print and copy, have faded result..
                try print .. still has faded result (this is to make sure that this is not a scanner problem)
                try copy .. same problem
                He have tried using 1 unit developing from machine 2 or 3.
                and .. same problem
                already 10 days.. not solved yet
                if the problem solved, i will tell you guys immediately
                • mramlawi
                  • Jul 2011
                  • 838
                  and .. same problem
                  try to remove laser dust filter
                  • ARUN MISHRA
                    • 80
                    Replace laser unit.
                    sigpicARUN KUMAR MISHRA
                    • techandtrader
                      • Jun 2016
                      • 335
                      There were many revisions to these Developers. If swapping them doesnt solve I would be looking at the lasers and checking the values. Maybe some mirror trouble in the laser?
                      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
