Spotches C3525i III
  • Radiscar
    • Jun 2019
    • 74
    Spotches C3525i III
    Hello, I have a weird issue a fellow tech has brought me. On gradation pages, the copier will print normal density of color except cyan and magenta will have darker splotches of the same color in them. I couldn't get him to show me a pg10 test and not enough data to confirm but no sign of repeating pattern for the splotches.
    After printing the first page, auto-gradation fails but he did say he was able to run a color mismatch.
    I had him
    double check if yellow/black were affected (he said nope)
    Swapped the paper with ours
    drums were replaced
    developer units were swapped/replaced.
    ITB was swapped
    2nd transfer roller was replaced
    laser assembly cleaned -and I can't think the splotches are caused by it.
    I'm hearing/seeing all this 2nd hand so be cynical. My next thought was to just backup settings and nuke the copier and see if that changes it.
    Any thoughts?
  • copier tech
    • 8184
    Do you have the print examples you could share here?
    As you stated a PG10 is a good one.
    Always worth updating the system software to cover all bases.
