IRC 3200 Don't Print, Repost for ricardobres
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    ricardobres05-11-2009 08:12 AM
    Hi guys, I have a IRC 3220, and the machine don't print.
    When I send a test print, the machine is not prints, but it proceesing on the display. If you check the printer status ( system monitor; Print ) the status is waiting to print, but the machine don't print. If you press cancel, the machine didn't cancel the job, on the Status, appear "waiting to print". The version are: DC CON 32.02; R CON 04.01; ECO 41.08; MN CONT 82.03; BOOT 70.01N; RUI 79.04; PS/PCL 41.10. I replaced the HDD with new system, but not resolved. If anyone has a clue and can help me
  • ricardobres
    • 147
    Thanks, mrfixit51.
    I don't know what happened with my thread, but....
    I put the IP adress, and the ping command is ok, when I send a test page, the machine didn't print, too.
    • mrfixit51
      • Oct 2008
      • 1975
      Were you able to get the RUI page displayed in your browser? The reason I ask is that there is also the ability to try a Direct Print operation from RUI. It is in the left hand column of the RUI webpage. I am curious about that outcome.
      • SCREWTAPE
        • Aug 2025
        You establish the communication, if you can ping it you can print to it.
        Are you using the right print driver?
        • ricardobres
          • 147
          • SCREWTAPE
            • Aug 2025
            [QUOTE=ricardobres;76015]
            • smiley
              • Aug 2008
              • 615
              i am missing something? i have machine 3200n then i change it with boot c the machine print from ufr the i chnge the 3200c with c1 i took c1 and change the boot with n but still the machine cant print in ufr or pcl it just say printing in process.and dosnt print at all.any body have a suggestion please.
              there is no glory without sacrifice
              • mtk525
                • Sep 2008
                • 8
                When you use a print card you need the boot rom firmware N installed. When you have a C1 or C2 Fiery with the interface board, you need the C firmware installed and under copier> options> img-cont you need to set it to 3.
