I have a ir-330 that we installed a B1 adf from a IRc 3200. When choosing 2 sided function only the first side is copied the second side is blank. WE have other units with these model adf and have never had this issue. Any tips, thanks
IR- 330 adf double sided blank on second side
Have you try that adf on one of the other units. If so,does the problem carry on? -
330 adf double sided copies
SCREWTAPE , We installed the adf on another ir-330 and the same issue. We also tried another K1 adf and the same issue It will copy the first side, reverse the original and leaves it on the platten on the right side and the scanner is scanning the left side, then ejects the original, the copy comes out with side one and the second side is of the adf belt. Is there programming that has to be done. thanks for responce.Comment
