canon clc 1150
  • stephen64
    canon clc 1150
    just bought a used copier as working ok but stapler unit not powering up. disconnected it from main unit fixed problem but when i reconnected it an error code was showing e072 0202. Any ideas?
    thanks
    stephen
  • SCREWTAPE
    • Jun 2025
    thanks
    stephen
    The error code points to the transfer drum area. Its the part the has that plastic sheet, its called a transfer sheet. When you open up the front door and pull out that section, that big round cylinder part, if you look under there is a green roller called the polishing roller which you can remove. Also there is a motor in that area that controls that part, sometimes that motor can cause that error code, make sure that its connected. Also if you look inside that transfer drum there are two parts call the attraction brush and transfer blade, they slide in the transfer drum,those too also could cause you that error code.
    • stephen64
      Hi
      Thanks for your reply, Could I have blown the motor reconnecting the booklet unit
      do I have to remove the green roller to remove the motor.
      with thanks
      • SCREWTAPE
        • Jun 2025
        Originally posted by stephen 64
        Hi
        with thanks
        No, the polishing roller can be taken off by pushing it slightly, its kind of held in place. I doubt that removing the sorter caused the problem. It probably just happens to be bad luck. These things happen. Chances are the motor probably isn't the problem in your situation, I just wanted to give you some sort of direction. If I was you I would call for service and have a tech look at it.
        • Canuck
          Tech Specialist
          • 1713
          The harness for the transfer drum assembly is noted for going bad...transfer drum assembly moves back and forth...wires break
          • geppinho
            Re: canon clc 1150
            try this:
            enter to setting( * 2_8 * )
            go to "adjust-clear"
            go to ONLY(important) "err-history" and "err" and press ok
            turn off the machine
            turn on the machine
