copy is smaller than the original (iRC3220)
  • sgcopiertech
    • Jun 2025
    copy from my machine is somewhat
    reduced / smaller than the original.
    the difference is small, but quite noticable
    when copying graphs or tables.
    anybody come about this problem?
    thanks!
  • nivssluck
    • May 2008
    • 228
    Check RATIO
    • kittybo
      is it just using feeder or when copy off the glass??
      • SCREWTAPE
        • Jun 2025
        Why don't you try initializing copy settings.
        Or is this happening when you print?
        • sgcopiertech
          @nivs, by ratio do u mean the xy in adjustment and cleaning? both r on 0
          @kittybo & screw: copying both on feeder n glass both gives smaller copy, i have also tried initializing the copy settings.
          thanks for your reply and hope to hear more. updates this coming week.
            If a original has straight lines on the extremes of the paper edge this feeder can make the lines appear a little 'wavey' due to the fact that its a belt holding the original, I havent found a way round this.
            Has the dc con been cleared without the codes put back in?
            • Canuck
              Tech Specialist
              • 1713
              Reduced in what axis...scanning(laser) or sub-scanning(scanner lamp) or both? Does it do it on prints also?
