Usb parallel (nethawk) cable.
  • SCREWTAPE
    • Aug 2025
    Canon is introducing the Release of a Limited Supply of the USB-Parallel Cable. "There back!" There releasing of a limited supply of the USB-Parallel Cable which are now available for purchase through the Canon Parts Warehouse. New part # FY9-4368-000
    For those who are working for a authorize dealer, get em while they last.
    Screwtape.
  • cdvidaceiba
    • 80
    great news!!!! thanks for the info Screwtape
    is there any way that someone that works with an autorized dealer can get a pair of cables to me , i pay!!!!
    thanks
    reynaldo.lopez@gmail.com
    • costd
      • Jan 2008
      • 409
      I am sure the is a misprint at ISG. DEALER COST is listed as US $188.68 per cable. In the last go round they were closer to $50.
      • SCREWTAPE
        • Aug 2025
        It is, what it is. They must of planned this..
        • davidj7
          • 1107
          canon sure is minting money on the cable
          a machine is only as good as your tech : source:screwtape ; the scary one
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            Screwtape my friend, you are right on time with this info.Have been looking to replace the one that i lost and havent been able to.Good timing!
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1888
              Unless there is something special, www.tigerdirect.com has them for $12.99.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                You will find out the difference between the USB Printer cable and the Nethawk cable the first time you try to use it...
                • SCREWTAPE
                  • Aug 2025
                  The nethawk cable is the only usb to parallel cable that is compatible to work with the SST.
                  All other generic USB to parallel cables are not compatible and will fail.
                  There is a big difference my friend.
                  • tmaged
                    • Oct 2008
                    • 1888
                    No problem, we're not a Canon dealer. Just throwing that out there.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • time2fly
                      • Jul 2008
                      • 134
                      I'm glad I got mine and held on to it for 3 years........
                      • cdvidaceiba
                        • 80
                        $254.83.....
                        • bnmand
                          • Sep 2008
                          • 383
                          According to google executive color used to sell the old version of this cable. Is the new nethawk cable likely to be sold on sites like that?
                          What would be really good though is if Canon found a way to bring Fixed IP to older models such as IR3300 doing away with the need for a nethawk cable altogether.
