Canon Imagepress C1 error code "e00061-0009"
  • infotect
    • Jun 2025
    I'v a Canon Imagepress C1, it didn't work after thunder and storm (bad weather) and show a error code "e00061-0009", anyone can help?
    Thanks more.
  • SCREWTAPE
    • Jun 2025
    Thanks more.
    Does this happen when you put the machine on or when you go to make a copy or print. At what point of the initial rotation. E61-0009, there is no listed remedy for that sub code 0009.
    • infotect
      thanks.
      c1 run to adjusting gradation...
      show error E000061-0015.
      Thanks more.
      • SCREWTAPE
        • Jun 2025
        Have you checked the primary corona ass'y? Clear the error first and then try to run a full auto gradation.
        • infotect
          thanks,
          how to check primary corona?
          thanks more.
          • Penvy
            • Oct 2008
            • 237
            You Could just remove it and look at the wire!!!!
            Or the service mode 2 level.
            • infotect
              thanks,
              & how to service mode?
              thanks more.
              • Penvy
                • Oct 2008
                • 237
                Ok heres where you can get into problems
                Friend you need to at least know how to get into the service modes.
                On the C1 there is 2 levels
                That much you must know if not even I feel you might be over your head.
                And I usually help anyone that asked.....
                This C1 is a real Bitch in the settings and you could change or even erase
                some very things that would just make it a door stop.
                • Canuck
                  Tech Specialist
                  • 1713
                  Thats right....if you don't know the C1...or yet how to even get in service mode on a Canon,don't play with it or like Penvy said it will become a door stop or boat anchor
                  • SCREWTAPE
                    • Jun 2025
                    Call a canon dealer if you are not tech. Some parts may have to be maintain or replaced.
                    • Penvy
                      • Oct 2008
                      • 237
                      I live on the bay .....should of used "Boat Anchor".........
                      • infotect
                        thanks more.
                        My C1 buy on ebay, canon dealer not support this C1.
                        Have anyone C1 service manuals, can mail to me?
                        Thanks, Thanks more.
                        • ommar
                          • Aug 2013
                          • 33
                          Re: Canon Imagepress C1 error code "e000410-01a"
                          i have canon image press c1 i want service manual pdf
                          Thank you so much
