I'v a Canon Imagepress C1, it didn't work after thunder and storm (bad weather) and show a error code "e00061-0009", anyone can help?
Thanks more.
Does this happen when you put the machine on or when you go to make a copy or print. At what point of the initial rotation. E61-0009, there is no listed remedy for that sub code 0009.
Ok heres where you can get into problems
Friend you need to at least know how to get into the service modes.
On the C1 there is 2 levels
That much you must know if not even I feel you might be over your head.
And I usually help anyone that asked.....
This C1 is a real Bitch in the settings and you could change or even erase
some very things that would just make it a door stop.
Thats right....if you don't know the C1...or yet how to even get in service mode on a Canon,don't play with it or like Penvy said it will become a door stop or boat anchor
