Canon IR5000 Scanner Issues
  • masterofpatience
    An Old Copier Doctor
    • Jun 2009
    • 55
    I have client with 2 IR 5000s which have been working well for over a year. Both machines would copy,print and scan without any issues.
    Last week one of the scanners started throwing incomplete images, broken images, and images with previously scanned text or images randomly inserted into new scans.(Pictures available on request) This doesn't happen every time. It could scan two pages and then glitch the next two. Plain text seems to scan better than text and images.
    According to technicians at HyTec Board Repair, the scanner resolution board is most likely the problem however when I went to remove the board from the machine, it's not there.
    According to Canon, the riser board and resolution board must be present in the single PCI slot on the main board of machine in order to scan. It is not present on either machine.
    If anyone has any recommendations I'm open to all suggestions because at this point I'm confused.
    Thanks in advance
  • SCREWTAPE
    • Aug 2025
    Thanks in advance
    Can you attach any samples.
    Does it happen when your copying or printing.
    The resolution board is a component for the universal send feature.
    The riser board is for networking (printing)
    Your using the the scanning feature that comes with the IR5000 standard.
    Do you put the scanner online in order to scan?
    The send feature works a little differently, you actually push scan to file folder,email account.
    As for the distorted images i would like to know if its just a scanning issue or if it happens while your printing or copying.
    • masterofpatience
      • Jun 2009
      • 55
      re: reply to IR5000 scanner issue
      Screwtape, Thanks !
      I have samples but no way to attach here. Need email address and I can send immediately.
      No the issue does not occur on ANY function except scanning.
      Yes, the scanner IS put online when scanning...
      • SCREWTAPE
        • Aug 2025
        Originally posted by masterofpatience
        Screwtape, Thanks !
        Screwtape@yahoo.com
        If you did not know. When you post there is a paper clip icon at the top of the message box, this where you can attach files.
        • masterofpatience
          • Jun 2009
          • 55
          Images
          Got it!! thanks for the assist... images are attached. The first is the original test chart the last 3 are the actual scanned images from the machine
          Appreciate the help
          • SCREWTAPE
            • Aug 2025
            Have tried reinstalling the network scangear tool driver, also what are you using, application wise? Have you tried changing the dpi resolution in the preview window. It sure looks like data processing transfering issue.
            • masterofpatience
              • Jun 2009
              • 55
              Have not tried reinstalling based on information provided by HyTec. Will go back and try that later today or tomorrow AM.
              • jprecht
                • Dec 2008
                • 104
                missing info on scan
                one copier is fine while the other has this scan issue? are they on the same network/server? has to be a driver issue suggest you try screwtape's advice and ck your setup . you could also try swapping your scanner hardware with working box. good luck j
                IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
                THAN TO SPEAK AND REMOVE ALL DOUBT
                • Canuck
                  Tech Specialist
                  • 1713
                  I can't remember if 5000s have smart scan...if so make sure it is turned off. I know 600s and above have it.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Smart Scan is a function of Universal Send, and the issue is with TWAIN Scan on th iR5000.
                    The MFP would need to be an iR5000i to have Universal Send.
                    Th iR5000 family came out about 5 years or so before Smart Scan was available.
                    • jprecht
                      • Dec 2008
                      • 104
                      was working
                      As both your boxes were flying would be interesting to know if client has recently upgraded server/network software. if one is still going are they both running the same version of firmware??? has got to be what "screwtape suggested " in the beginning. go back and ck the basics then hdware. good hunting j
                      • Canuck
                        Tech Specialist
                        • 1713
                        To KenB....SmartScan is not a part of Universal Send....IR600 has it...no Universal Send. It is in additional functions in User Mode...IR600 has is it but IR550 doesn't...there is an additional memory pcb that connects to the IP pcb on the 600.But i checked and not on 5000
                        • masterofpatience
                          • Jun 2009
                          • 55
                          Problem Solved!
                          It would seem that it was indeed the software. Tested the scan from the same IR5000 to a completely different computer on the same network and it worked without incident.
                          Re-installed NSG 2.2 and everything works great.
                          All the assistance is much appreciated.
                          • SCREWTAPE
                            • Aug 2025
                            I glad it'd worked out for you. Thanks for posting back.
                            Screwtape.
