toshiba BD1510
  • sunny
    • Sep 2024
    toshiba BD1510
    Can anyone help me , i replaced drum developer blades and heater.
    I now you have to do some calibration.
    Problem now is at multi copy after 15-20 copies picture gets black stripes.
    I have manual but no codes for adjusting are listed
    kind regards johan
  • Copier Systems
    Toshiba-1550
    kind regards johan
    Look at sim08 or 05 in service manuel follow directions let machine run until it stops*if the #are not in the range of manuel use zoom keys to change # that is in op-panel press inturrupt to lock in turn off an back on that part is finished. I dont understand the heater replacement be a bit more specific on that one.if you need more help i will look at my manuel which is at the office an list stepts dv-cal should clear up the other issues
    if not post problem.Good Luck Andy H.
    • sunny
      bd1510 problem
      dear andy,
      My service manual does not cover the adjustment tree for 05 and 08.
      can you copy this to me
      kind regards johan
      • Copier Systems
        Toshiba-1550
        My info is out intrivia an will not copy. list the adjustments you need an i will list them.
        1.Did you do dv-cal
        2.Do you still have bands on copy
        3.Did not understand heater replacement?be more technical on that one.
        4.Tell me your original problem an what your diagnosis was and this will give me a better picure of your problem.will await your response.
        Andy H.
        I have a few toshibas out there
        • NannuProgs
          IR3300
          Please someone help me in this problem.
          A Conon IR3300 Everything looks good but there is no copy (I mean th paper comes blank). No error code exept finishing error.
          Thank U for Ur time.
          NannuProgs
          • Copier Systems
            Cannon-Blank copy
            Ck-dv unit make sure it is locked Stop copier after it scan original(do not let it return to the home position. is there an image on drum?if no image is visable ck charge corona If you have image then ck transfer i thank that unit uses a transfer-roller.
            Gool Luck. Andy H.
            • sunny
              bd1550 toshiba
              Dear andi,
              1.I did not do a dv cal although i know i had to do this, can you explain me how to do , it was not listed in my part of the manual.
              2.The bands are coming after i make 25 copies in repeat 1 per 1 or 5 each is no problem
              3.I replaced just heater blade because it was damaged.
              4.The original problem was always black bands.i did a PM replacing drum, drum blades and developper and cleaned inner of the machine.everything looked fine exept the above mentioned.
              maybe i forgot somthing else important to do , can you advice me.
              many thanks sunny
              • WOETC
                BD1510 Dev Setup
                All the Analogue Toshiba Copiers have the same Developer set up. You have to do the Auto Toner Adjust. It is not in the Service Manual. That deals with taking it apart and putting it back together; it is in the Service Handbook. To adjust the auto toner settings, Power on with the 0 and 5 keys depressed. When it comes up enter 0 then Start. It should run for about 2 minutes, then stop, when it does that I think you hit Interrupt to Store the data. (That was a long time ago) You adjust the lightness and darkness of the copies in 05 mode using codes 1 through to about 8, sometimes more depending on the enlargement and reduction ratios. That should get your image right, If you still have probs drop a thread and I wil see if I can find the data for that model.
                • WOETC
                  Canon IR3300
                  Does the machine print. I'd go into service mode. (Additional Functions {*} 28 {*}> Function> Misc P > P Print> OK. That should print out a complete list of the machine settings. If nothing comes out on the paper, I'd suspect the High Voltage. Step 1, do a copy, and stop the machine while the paper is halfway through. Is there any image on the drum. If yes, check the transfer roller. If no, check that the Developer unit is lifting OK, and that the contact between the drum cartridge and case are good.
                  • sunny
                    adjusting copies in mode 5 description of functions 1 to 8
                    Hello,
                    Till so far it worked i only have some black distorsion on the sides of the paper. I can get rid of it by plaing around with the numbers in settings 1 to 8 .
                    I would be more happy if i can set them in the correct way.
                    Is ther anyone who can copy me the settings for this part of the machine.
                    function 05 and 08 would be helpfull.
                    kind regards sunny
                    • yumacopiers
                      • Mar 2007
                      • 35
                      check drum grounding
                      toshiba analogs are notories for dark bands when drum grounding is poor....if that is the problem use conductive lubricant....
