Error code 355 and 350 in Canon IR 2220i
  • hari_4848
    • 91
    Im getting this error code in the machine ir 2220i.
    Im unable to understand what is the problem.
    Help needed.
    Thanks.
  • SCREWTAPE
    • May 2025
    Help needed.
    Thanks.
    Problems in the main controller area.
    The E355 error code is due to no communication between the Main-Controller board and the Serial Number board below it. The boards are connected by a 11 PIN yellow connector and cable. This yellow connector must be reseated on the new Main-Controller board when changed. The connector must be seated firmly on the board.
    When this error occurs, you must go into Service Mode and clear the error code.
    How to clear the error code:
    1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
    2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
    3. Under the [FUNCTION] tab, select the [CLEAR] option.
    4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
    5. Reboot the machine.
    If the error occurs again:
    1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
    2. Reseat the Main-Controller board into its slot.
    3. Go into service mode and clear the error code as explained above.
    * If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
    Screwtape.
    • wingnut132
      • 65
      E350 is soft ID PCB Faulty and E355 is counter pcb problem. Have you cleared the code in service, if COPIER>Function>CLEAR>E355-CLR], press the OK key to clear it
      • imageindia
        Replace the set of Counter pcb & Serial pcb for E355
        check the conection between counter pcb & monitor pcb for E350
        • MichaelConway
          Canon Man
          • Jun 2009
          • 17
          This fix will have to go through Canon. They will have to get a serial number and then send you out a Main Controller and Serial Number PCB as a set. I had this happen to me one time.
          Michael Conway
            • 22930
            These errors usually result from some shmuck trying to reset the total counter. Tell me I'm wrong, please.
            • SCREWTAPE
              • May 2025
              Ding,Ding,Ding,Ding,Ding,
              I believe your correct.
              • dzoisme
                almost :
