Clc1180 will not enlarge correctly
  • rlr42173
    • Mar 2007
    • 28
    My clc1180 will not enlarge correctly above 175% ratio.
    The scanning lamp will pre-scan and then scan once again, but then the lamp does not move again it just sits there through the 4 color scans and remainder of the job, then the copier will become unresponsive and lock up, so I have to turn it off then back on to be able to use it again.
    I have replaced the scanner board and the scanner motor as well and the ps1 sensor. I am out of ideas on this one short of replacing the dc controller.
  • SCREWTAPE
    • Jun 2025
    Are they any recent error codes in the history?
    • rlr42173
      • Mar 2007
      • 28
      Any error codes
      The copier is working just fine, except for the not being able to enlarge. Last code was e351-0000
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        just on the off chance...
        Have you tried to move the optics all the way to the right of the optics area? 1180's have been around a long time, and you could have some binding occuring in the optics, especially if enlargement is not done very often. Clean and lube the rails, and give it another try.
        • rlr42173
          • Mar 2007
          • 28
          Clc1180 Not enlarging Response
          Ok I will try that and post the results. Thank You for your prompt response.
