how do i move the trays?????!!!!
+ More Options
Posts
  • smiling daisy
    • Sep 2025
    so the trays on the side of my copying machine, you know where the finished copies land? well, it's been moved above the point where the copies spurt out of and i can't get it to move back down. HOW DO I DO THIS? any help is greatly appreciated!! thank you so much! i just can't figure it out!
  • roho
    • Mar 2009
    • 844
    try turning copier off/on
    • smiling daisy
      i did try that...it seems that they have to be moved manually. there are tracks that run up the copy machine, and the tray hooks on to a track when moved. it seems that i can only move them up not down; as if the hooks won't let go. does that make sense?
      thank you for your help! this is so frustrating and i'm really grateful for your suggestions
      • SCREWTAPE
        • Sep 2025
        First of all, what machine and what finisher are you having a problem with?
        • roho
          • Mar 2009
          • 844
          does the screen on the copier say limited functions mode(bottom of screen)?
          • smiling daisy
            it's a canon 5070 with a finisher T-1
            • smiling daisy
              it doesn't say limited functions mode, but it does say that the finisher can't be used.
                • 22995
                You've had some kind of an error on the finisher only allowing partial functioning of the MFP.
                • roho
                  • Mar 2009
                  • 844
                  ok, you need to press "additional functions"-"common settings"-"limited functions"-turn this "off"-properly reboot the copier. the trays should find home position now.
                  • SCREWTAPE
                    • Sep 2025
                    Go to additional function, common settings, look for functions limited mode, turn it off and reboot. Chances are you got a E540-. Check the flag arm sensors they sometimes break and the tray are seeing blind right now, if they don't detect home position the machine will error out.
                    • smiling daisy
                      [IMG]file:///C:/DOCUME%7E1/ADMINA%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG] the left side of this picture, the trays, that's what i'm having trouble moving...i thought maybe a picture would help me make more sense.
                      and blackcat, i know there's an error, how would i fix it?
                      • smiling daisy
                        You guys are awesome!
                        It worked )
                        you are so much better than the support people on the phone.
                        You are fantastic.
                        Thank you so much!!
                        • smiling daisy
                          all of that was in caps, by the way. i don't know how the lowercase took over.
                          • SCREWTAPE
                            • Sep 2025
                            It worked )
                            You are fantastic.
                            Thank you so much!!
                            That's what we are all here for.
                            • roho
                              • Mar 2009
                              • 844
                              glad to hear it worked! suggestion-many times this situation is caused by having recycle boxes under the trays-may not be applicable in this case.
                              Usually the finisher has very little trouble otherwise!
