IR6000 "please wait" message after switching on
  • Tech109
    Hi
    Thank You,
  • SCREWTAPE
    • Jun 2025
    Originally posted by Tech109
    Hi
    Thank You,
    Ethier bad firmware or bad HDD.
    You can try reseating the dimm chips and the bootrom.
    • ymmtech
      • Jun 2009
      • 191
      Look like R Con not responding.
      Goto service mode (* 2 8 *),>copier >IO >RCON. See if all address return data 0(non of the bit =1)?
      • SCREWTAPE
        • Jun 2025
        If the copier is stuck while its trying boot up, you really can't get into service mode to check how R-CON is doing. You can't do anything but check out the system area part of the unit. Which was, Ethier bad firmware or bad HDD or bad dimm chips and or a bad bootrom.
        • Guest
          Yer HDD
          • ymmtech
            • Jun 2009
            • 191
            If the progress bar stop at 40% or 60% it is HDD don't boot properly.
            If it reaches 95% and still wait there, you have a hight change to get into service mode.
            • SCREWTAPE
              • Jun 2025
              OK
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Originally posted by SCREWTAPE
                OK
                Lol screwy
                • CanonHPTech
                  • Apr 2007
                  • 235
                  Keep it simple... check your connections first to all accessories like Finisher and Feeder, then try unplugging all of the connections and powering on. Reseat BootRom and any DIMMS and while your in there reseat any cables going to the Main Controller. Listen to Hard Drive see if you can hear it clicking, or spinning up and spinning back down. More than likely it is Hard Drive due to age of machine. Hard Drives are only rated for 3-5 years. Please post results.
                  The glass maybe half full, but less is more...
                  Printer + Fax + Copier = Jack Of Many Trades,
                  but Master Of None
                  Color Copier = Not A Color Printer
                  InkJet MFP = Not A Fax Machine
                  B/W Copier = Not A Press
                  Finisher = Deal Closer (salesman, not accessory)
                  Copier Tech = Admin's Stress Ball (Scapegoat)
                  • Dimacop
                    • 43
                    hi to all
                    ja change hdd
                    dimm and flash rom
                    and still no wait
                    someone has an idea???
                    Thank you and good weekend
                    • mtech
                      • Mar 2007
                      • 307
                      After you try to copy and the machine says suspended, check the job status. I am almost 100% sure you will see a red add staple icon on the screen. Replace the staple cartridge and you should be all set. If the staple cartridge can't advance this will cause the issue. Very common with Canon.
                      • freeman
                        hdd
                        Hi
                        Thank You,
                        try *28* then chk ur hdd it ll start 99% to 0% if stops b4 0% then chg ur hdd
