Canon 6551
  • maks
    • May 2008
    • 75
    Canon 6551
    gud morning,can i please ask for suggestions regarding this machine..When we make copies the first one comes out clean and clear but the next copies that follows has marks or images or shadows left on it..the more the copies made the the darker the shadows can be seen.that is in AUTO exposure mode..and when i tried it in manual mode and tries to lighten it, the copies comes out clear..thanks for any help..
  • wareagle
    • Jul 2025
    sounds like primary corona wire needs to be replaced. Do you get lots of black specks?
    • roho
      • Mar 2009
      • 844
      np6551 would have potential control. Usually if it is on, copies come out light when wires are worn. However, the opposite can happen when it is off. Try checking potential control, if it is off, activate it. If copies come out lighter, change primary, xfer wires. Leave potential cont on.
      Good luck!
      • euro scott
        • 127
        i would also look at the drum cleaning blade. when they go bad they can cause similar copy quality issues.
        • 20YRSEXP
          • Oct 2008
          • 281
          Are you an end user? or a tech? The primary sets the charge to attract toner not like the digital machines where the primary sets a clean charge. I would more likely suspect the cleaning lamps or the mirrors. When was the last time you had a good cleaning and PM done on this? It could be a cleaning blade issue also. If the fixing unit is badly worn you could be getting offsetting from the rollers. some additional info would help. if you are a tech shut off pot cont and see if there is a change. Stop the page (after a few have come out dirty) before the fixing unit and see if it is dirty at that point. If it is then you can rule out the fixing assembly. If it is clean you can rule out the image formation.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • maks
            • May 2008
            • 75
            canon 6551
            thanks for your replies...yes the copies comes out dirty after passing the drum assembly and not after the fixing unit...but to tell you the truth this will be the first time im going to check the drum assembly and i have no idea how to do it?except that i think ill have to remove the developing unit first before proceeding to the drum unit itself?am i correct???can the cleaning lamp be removed without removing the drum assembly?is it complicated to removed..is it the same way as removing the drum unit of IR 105?can you please give hints..
            • 20YRSEXP
              • Oct 2008
              • 281
              That's an old machine, I don't see many of them any more, but I do remember it is similar to the 105. I think you can remove the cleaning lamp without taking out the drum unit. It is attached to the drum unit, but I think there is one screw on the front to the left of the primary and the unit slides out. But I think removing the drum assembly is a good idea so you can look at it and clean it. You should see the blank lamps and the cleaning lamp come on when it runs. Tough to troubleshoot a copy quality issue over the internet I would cetainly start with a cleaning including new corona wires and clean the optics. I would also check to make sure there is no paper in the drum/cleaning unit.
              • roho
                • Mar 2009
                • 844
                Yes, you need to take out the dev first. If you have done a 105, you'll find this similiar. The cleaning, blanking is part of the process assembly.
                It's been a while since I removed this assembly from this machine.
                • maks
                  • May 2008
                  • 75
                  canon 6551
                  thanks for the hints..try to do it on saturday...
                  • euro scott
                    • 127
                    another tip for you as I remember is the cleaning blade is reversable, actually has 4 edges
