Canon IR2200 show wait and error code E247
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    I have a Canon IR2200. It's show wait while it is always open machine.
    I have changed main controller unit with counter board and dc controller unit. Can anybody help me.
  • SCREWTAPE
    • Jun 2025
    E247 can be displayed when there occurs a mismatch between the soft counter data maintained in the counter memory PCB and the main controller PCB respectively.
    Replace the counter memory PCB with a new one.
    The counter memory PCB is not assigned as a service part. Please contact a division concerned for procurement.
    These actions must be done respectively.
      • Dec 2007
      • 71
      Thank you so much.
      Wat
      • mrsoul
        • 18
        Hi, please take note when replace any main controller must make sure use back the counter pcb, or elase you will face this error code, new counter pcb only can be replace when the machine run up to the counter limit, you can replace when facing this error.
          • Dec 2007
          • 71
          OK. Thank you very much.
          Wat
          • jose dai
            • Dec 2008
            • 25
            replace the counter pcb the original one or ,simulate the error E247 diconnecting the serial pcb,switch off,and then on the error will apear and swittch off reconnect the serial pcb and the new soft counter
