canon ir5000 blank display ,no error
  • cdvidaceiba
    • 80
    hi got a canon ir5000 that powers up , but no indication is displayed on the screen , the machinne does the cicle and no error is displayed , the control panel is ok i had tested in other machinne and works ok , any ideas ??
    thanks in advance
  • bnmand
    • Sep 2008
    • 383
    thanks in advance
    There has been a similar issue regarding an IR105 posted recently.
    http://www.copytechnet.com/forums/ca...elp-again.html
    It's possible that the drum cleaning assembly having problems is also the cause in an ir5000.
    • cdvidaceiba
      • 80
      thanks Bnmand , but can you be more specific , what secction of the drum cleaning assy is giving me this problem , thanks in advance
      • cdvidaceiba
        • 80
        other thing , the control panel doesnt respond to any comand , no copies can be made , no prints can be made also , the brightness knob doesnt respond , but if i install this same control panel in other machinnes works ok
        • bnmand
          • Sep 2008
          • 383
          Take a look in the thread I linked to. The IR5000 is around the same age as the IR105 and it's highly likely that they're similar machines and share some of the same problems.
          There is a thread on the blank LCD issue for the IR5000: http://www.copytechnet.com/forums/ca...ir-5000-a.html
          Try the things mentioned there such as reseating and if that fails replacing memory and replacing DC PCB.
          • cdvidaceiba
            • 80
            ok thanks , exelent !!!!
            • 20YRSEXP
              • Oct 2008
              • 281
              Usually a blank screen on the 5000 is the Dimm. Try reseatting the Dimm and the boot rom.
              Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
              • SCREWTAPE
                • Aug 2025
                I agree. Why don't you swap the bootrom and dimm chips from the other machine. First try the bootrom if that don't work try the dimm. If both don't resolve the issue you might a bad main controller.
                • cdvidaceiba
                  • 80
                  in case is the boot rom i have the option to rescribe it with the SSt???
                  • SCREWTAPE
                    • Aug 2025
                    You can try,
                    it won't hurt.
                    • bnmand
                      • Sep 2008
                      • 383
                      Originally posted by SCREWTAPE
                      You can try,
                      it won't hurt.
                      Agree. Worst case scenario for the boot-rom is that the boot-rom is dead and it needs to be replaced. If so be sure to get one of the same type e.g. if the dead one is a C version get a C version etc, that is unless you want to network it. I've seen network kits starting at around $100USD including postage on ebay so if worst comes to worst and you have to replace the boot rom it's not too bad.
                      • smiley
                        • Aug 2008
                        • 615
                        try to relpace your ram.swap it with other working machine.
                        there is no glory without sacrifice
                        • mitsubee
                          • 176
                          I got this problem before..... No Display NO Error Code Machine got power ...... BootRoom need to be clean up...or bad fit in.
                          • cdvidaceiba
                            • 80
                            • SCREWTAPE
                              • Aug 2025
                              Just to give you the a heads up the 5000s requires two bootroms, one to boot up the machine and the extra one is the one that gets flashed when you start updating. This unit has the older main controller.
