Canon ir2870 Error e000100-0001
  • drakanthesly
    • Aug 2025
    Hello I am new to the forum and highly appreciate your forum and knowledge.
    I have a canon ir2870, and I am receiving error code e000100-0001, telling me to turn the printer off and then back on, same error everytime I try to use it. I have read the forums, and it seems to be a DC Controller? Please let me know if it could be something else.
    If that is most likely my issue, can anyone please direct me to a website I can purchase parts from? I'm not having any luck buying them from eBay.
    Also, this error started after my wife tried using sticky labels from the drawer when I wasn't home, if that could cause a problem, and you have any suggestions pleaes let me know, I really need this machine back up and running.
    Thank you!
    Paul
  • bnmand
    • Sep 2008
    • 383
    The error hasn't gone away because the problem's still there.
    Get a tech to fix this.
    • drakanthesly
      If I wanted to pay a tech I wouldn't be posting. I'm extremly tech savvy, and I can do anything with a computer - but I havn't learned any canon error codes, or cared to find a location that sells Imagerunner parts recently. 97k printed on it, if that means anything to the issue.
      By the way, what I meant by same error everything I use it, is the same error everytime I try to use it, meaning after I have tried something to remedy the problem. No point in trying to remedy something that is beyond my knowledge - but I wish to learn - hence my post.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        E100 error codes are associated with laser / controller issues.
        It could be something as simple as a loose connector, or a major meltdown.
        As bnmand stated, you really need a qualified tech to check this out.
        It will cost you way less than tackling it yourself.
        • Brian8506
          • 1665
          A good tech will fix it. That's what we do.
          • drakanthesly
            Well at least you gave me a reason. I apologize.
            Know any good techs in Michigan? Redford area.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Just a thought...
              Are you sure that you accounted for all the labels that you tried to print on?
              Maybe one of the little critters came off inside the machine, (they do that a lot, especially the "non-approved" brands) and is blocking the laser, pulling on a wire, etc...
              • drakanthesly
                Yeah, none came off, all still on the sheet of paper. I wish that was the problem trust me.
                • SCREWTAPE
                  • Aug 2025
                  When you close the right side door the laser shutter opens up.
                  There's a possiblity that the laser shutter is blocking the laser.
                  You can also hear the laser fire up when you put the machine on
                  or touch any of the keys. If you don't hear that high pitch noise
                  then you have a bad laser.
                  The only fix for this is checking out that laser or shutter.
                  • drakanthesly
                    Alright, I will check that tomorrow morning, but I'm fairly certain I can hear it. I will look for the shutter.
                    Thanks!
                    • SCREWTAPE
                      • Aug 2025
                      Thanks!
                      I have seen that shutter get stuck and cause E100
                      Open up that left side panel, four screws. But i would
                      Call for service, you might need a part anyway.
                      Save yourself the trouble and time.
                      Goodluck.
                      • alex@wocltd.com
                        • 430
                        seeing this more and more often -specially after transport - the laser SAFETY shutter assembley breaks - get a tech but ask him to bring part beforehand
                        • SRINATARAJAN
                          Re: Canon ir2870 Error e000100-0001
                          hello i am new to the forum and highly appreciate your forum and knowledge.
                          I have a canon ir2870, and i am receiving error code e000100-0001, telling me to turn the printer off and then back on, same error everytime i try to use it. I have read the forums, and it seems to be a dc controller? Please let me know if it could be something else.
                          If that is most likely my issue, can anyone please direct me to a website i can purchase parts from? I'm not having any luck buying them from ebay.
                          Also, this error started after my wife tried using sticky labels from the drawer when i wasn't home, if that could cause a problem, and you have any suggestions pleaes let me know, i really need this machine back up and running.
                          Thank you!
                          Paul
                          it is only communication error you clean the transfer and charging pc rollers and reset the error code by using all ram clear.
                          • SRINATARAJAN
                            if necessary ple call +919884234000
