Restarting a C1
  • Penvy
    • Oct 2008
    • 237
    Restarting a C1
    I am going to to a complete cleaning in the ITB, atr, dev cylinder assy, toner waste, grids and paper feed/path.
    As fresh start to see how the dev units will last before 60K this next time.
    Is there something else in the Svc mode level 1 or 2.
    I want to be very careful on the starter ratio's/mix
    could just do the auto gradation but wanted to ask on any new hints.
    Did the print out of all settings/door settings and even noted the ratio's
    changing.
    Also kept the original ones on installation.
    I have to dig up all my notes on the past performance(not good) but
    would like to see what changes on the svc manual if any on the newer ones.
    got a early 06"
    did not see anywhere in the manuals for starter kits.
    But now the starter kits can be found!
  • SCREWTAPE
    • Aug 2025
    changing.
    got a early 06"
    Not much has change with the procedure when redeveloping the developers. If you have done this before you should not have no problem.
    • Penvy
      • Oct 2008
      • 237
      Thanks ,Had to ask.
      This is one of those times where you have so much in a machine you want to make it work just to see if you can.
      Canon should have done much more R&D and
      come out and say you have to do a refresh every 70K.
      good grief were doing for them.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Shouldn't be that different to a 6800 I would think...restart the devs..initialize them...Full A.Grad and you should be good to go...let us know how you get on.
        • Penvy
          • Oct 2008
          • 237
          Damn didnt even think of a 6800
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Thanks ,Had to ask.
            We don't even offer IPC1 as a color solution any more...it's either 2550i or 5185...and whenever I approach a C1 issue I stop to think what would I do if it was a 6800....doesn't always relate but sometimes it works.
            • Penvy
              • Oct 2008
              • 237
              So what do you think Canon is going to do with
              the C1?
              I do remember it was for proofing at first.
              then I read about the C1+.
