I'm new to copier repair, so bear with me! I have a Canon CLC 5000 and am getting an error code E005-0001 "switch power OFF and ON again". I've turned the machine off & on several times waiting several minutes in between and am still getting the same message after machine restarts.
I'm wondering if I just need to clear the error code? The machine stopped midway through a run and the bypass feeder tray is stuck up in the feed pos:confusediton.
I can get into the service mode, but from there I'm not sure where to go. Any help would be greatly appreciated!
Kari
Kari
