i have all of canon service+SST
  • Mike83
    #121
    Re:C2880i
    Hello,
    I have a Canon C 2880i machine. Since resetting all setting, I get a
    "RemoteUI Contents is Not Found!! RUI Module Version : 9101" error.
    Can anyone please help me with SST + latest firmware for the C2880i machine?
    PS: I know this is my first post but you always usually start when you have problems...
    • teckat
      • 16083
      #122
      Re: C2880i
      Originally posted by Mike83
      Hello,
      what did u re-set that u lost RUI
      did u check the Printers Firmware Version list to see what is loaded in ?
      Service Mode/Copier/Display/Version
      Do u have HTTP and RUI enable on the copier
      The correct version of RUI firmware must be flashed onto the copier. A specific version of the RUI firmware is required for each individual version of system software (MN-CONT Firmware) for each specific copier model. The correct version of the RUI firmware to be used with your current version of MN-CONT software can be found on that system software version's System Software-
      To correct this problem:
      1. Flash the copier with the correct version of RUI firmware.
      2. Be sure to enable HTTP and RUI on the copier.
      3. Be sure to enable "Dedicated Port" on the copier.
      NOTE: For MEAP Enabled Devices, please make sure that the proper MEAP version in Service Mode/Copier/Display/Version is also installed. If everything fails, perform a Clear MMI. Also note that on MEAP enabled devices, USE HTTP under TCP/IP Settings and USE HTTP under MEAP Settings must be ON.
      also > make sure under
      Additional Functions>System Settings>Network Settings>TCP/IP Settings>Multicast Discovery>is OFF.
      • Mike83
        #123
        Re: i have all of canon service+SST
        I did a "clear all settings" within the advanced functions menu. The first time everything went well but I got an error message that the "defult key" is broken. Therefore I did the "clear all settings" again with the described result.
        My system version seems quite up to date (if March 2011 is the latest version)
        http://www.copytechnet.com/forums/sh...rmware-version
        DC-CON 66.02
        R-CON 50.01 (this seems to be outdated)
        Panel 00.02
        ECO 41.22
        Feeder 1.00
        NIB 5.00
        MN-Count 93.02
        RUI 91.01
        Lang en 61.01
        Lang de 93.02
        Lang it 61.01
        Lang jp 93.02
        Meap 93.01
        OCE-jp 20.04
        Bootver 76.01_C
        TTS ja 05.01
        TTS en 05.01
        WEB 75.02
        Help 87.01
        Webdav 80.01
        Asr ja 04.01
        Asr en 04.01
        • mikejose
          • Oct 2013
          • 35
          #124
          I'm no expert on Canon machines so I suggest you follow the advice of tekcat.
          • teckat
            • 16083
            #125
            DC-CON 66.02
            Panel 00.02
            ECO 41.22
            Feeder 1.00
            NIB 5.00
            MN-Count 93.02
            RUI 91.01
            Lang en 61.01
            Lang de 93.02
            Lang it 61.01
            Lang jp 93.02
            Meap 93.01
            OCE-jp 20.04
            Bootver 76.01_C
            TTS ja 05.01
            TTS en 05.01
            WEB 75.02
            Help 87.01
            Webdav 80.01
            Asr ja 04.01
            Asr en 04.01
            1-what Language are u using on this printer
            the System ver. (MN-Count 93.02) needs to exactly match the Language ver. being used/ right now it's only on German & Japanese /
            that's the first issue if you intend to be using English
            2-your Firmware versions need to be reloaded/ or all updated
            3-who told u to clear all settings ????
            What ADVANCED Settings are u talking about ???????
            4-the RUI is loaded in----
            5-"defult key" is broken--* Note - Any key pairs or certificates imported onto the copier must be registered to be used. You can only register key pairs that use the RSA algorithm (the DSA algorithm is not supported). To delete a key pair or certificate, you will need to disable SSL for all the protocols that support SSL on the copier (ex. RUI, IPP, SMTP, POP, Device Information Delivery, MEAP).
            Additional Functions -> System Settings -> Network Settings -> TCP/IP Settings -> Dept. ID Management Password Confirmation / make sure this is set to "OFF"
            How to clear out the message Default Key is Corrupt
            1. Enter service mode * 2 8 * > * 2, for level 2
            2. Copier > Function > Clear > highlight CA Key - press OK.
            3. Power copier off, then back on - Default Key is Corrupt message should clear.
            IMPORTANT NOTES:
            In some case although the above procedure was followed, “The Default Key is corrupted or invalid.” message is still displayed.
            Please perform the following procedure.
            1.Install the key and the CA certificate using Service Support Tool.
            2.Turn the main power OFF and ON.
            3.Clear CAKEY. (Service Mode Level 2 > COPIER > FUNCTION> CLEAR > CAKEY)
            4.Turn the main power OFF and ON. * After this procedure is performed the key and the CA certificate will be set to the default values.
            If u don't have a KEY# or CA --- Make one up
            If the message did not clear perform the following to create a new key:
            1. Additional Function> System Settings> Network Settings> TCP/IP Settings> Certificate Settings 2. Select Generate Key
            3. Enter Key Name: input any name (Default Key)
            4. Select 1024 for Key Length
            5. Enter the Current Date as the start date
            6. Enter the End Date with current Month and Day and the Year - 2032
            7. Select Start Key Generation
            8. Go back to Certificate Settings and select Key and Certificate List
            9. Select the corrupt Default Key and press Erase
            10. Cycle power.
            • Mike83
              #126
              • kkkx2
                #127
                I want SST firmware ir3300i and ir4570 pls.
                Thanks for your kindness ^ _ ^
                mail contact: kraisorn_bey@hotmail.com
                • smokinbull
                  • Jan 2011
                  • 20
                  #128
                  hi yes i would like 7105 sst thanks bill
                  • robert320
                    #129
                    hi,
                    do you have firmware for canon irC2380i +sst for me, please?
                    mail contact: jupiter.olymp@gmail.com
                    regards robert
                    • nooy
                      • Mar 2014
                      • 5
                      #130
                      Originally posted by harnrak
                      if anyone want to have all of canon service support and any Tell me. but now i want to clone harddisk from the old one to the new one. Who have any idia pls tell me and i will share canon service support to all of you
                      harnrak@yahoo.com
                      PL i m a member of canon dealer
                      Dear Harnack ,
                      Please i need iR1022IF system firmware and SST.. can you please kindly send to me?
                      nooy82@gmail.com
                      • elamurugu
                        • Mar 2014
                        • 27
                        #131
                        hdd
                        downlord hd clone and copy hdd
                        • copdoc
                          #132
                          would you help me wth sst and firmware for canon ir 2520
                          • Frits
                            • Jun 2009
                            • 62
                            #133
                            Can you mail me the SST version version 1.050 to info@hcsm.nl
                            • ZOOTECH
                              Senior member of CRS
                              • 3375
                              #134
                              Originally posted by JustManuals.com
                              No.
                              Now we know you're back and with a 'softer' side.
                              • peterqt1
                                • Apr 2013
                                • 3
                                #135
                                Dear Harnack ,
                                Could you please email me system firmware and SST for Canon Imagerunner 4080i and 5185i ? Thank you.
                                peterqt2@yahoo.com
