IR3300 - E-345
  • Matoku
    • 173
    IR3300 - E-345
    WHAT IS THE DESCRIPTION OF THIS E-345 ON IR3300. IT NOT INCLUDE IN THE SERVICE MANUALS ERROR CODE LIST.
  • Blues Guy
    • Aug 2009
    • 216
    The problem is related to your serial number and counter board.
    • SCREWTAPE
      • Aug 2025
      The counter board must stay with the original main controller. Its married to it.
      • davidj7
        • 1107
        screwtape: what happens if the counterboard is faulty? if replaced with a new one will it match the MFC
        a machine is only as good as your tech : source:screwtape ; the scary one
        • SCREWTAPE
          • Aug 2025
          Yes, but you must call canon in order to get one.
          • nivssluck
            • May 2008
            • 228
            I have many serial and counter pcb....
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              And when you call Canon, they need the current serial number of the copier, same one as physical number on rear cover, to create a new counter board for you. And if I recall this correctly, you have to ship them the "defective" counter board before they will issue the replacement.
              • okeetee
                • 16
                E345 :
