I have a Canon 6016 that gets E007 Codes. The fuser looks fine and has been replaced but I still get the codes every so often. I think I missing something, any tips out there
E007 code on a Canon 6016
hood4472
Re:E007 code on a Canon 6016
This problem came from the fuser film not jogging back and forth over the sensor. Did you run the adjustment for installing a new fuser film when you installed the fuser? Other than that, just check to make sure the film isn\'t broken or missing a piece. Good luck.
Robin
